VPEX auto-config detected a cascaded BPE on a BPE slot that does not support cascading. The BPE detection will be ignored and no associated VPEX configuration will be added.
Reconnect the subtended BPE to the controlling bridge directly or to another BPE which supports cascading.
Warning
BPE slot %slotNo% does not support cascading
| Name | Type |
| slotNo | uInt |
